Зворотний зв'язок Мапа сайту
4Drawing - Interactive Electronics Frame DFRobot
код: KIT048
  • 4Drawing - Interactive Electronics Frame DFRobot
Combining electronics, art and daily creation is always our passion, thus we created this kit. Creator 4Drawing Kit is a perfect DIY kit for kids, artists, tinkers and interactive designers. Through simple connections, you can easily bring life to your wonderful paintings. Kids will not only learn basics of circuits but also experience the magic behind interacting with sound, light and electronics. This kit is super fun to play, and is compatible with most Arduino sensors and actuators. We also offer three coding choices for different skill levels so that you can start playing fast with tutorial.
The main board in this kit - Pallete is a customized board for this interesting kit. It is fully compatible with Arduino (type LilyPad Arduino), and can be used as standalone microcontroller. Pallete features a low power consumption design, and is capable of power switching external modules and power wake up via sensor, which is suitable for many other interactive applications.
FEATURES
  • Be an interactive artist!
  • Simple connections
  • Compatible with mutiple sensors, actuators
  • DIP prototyping area makes it easy to add more chips
  • Full range of coding modes: plug & play, graphical and freestyle programming
SPECIFICATION
  • Frame Dimension?352 x 274 x 30mm(13.86 x 10.79 x 1.18")
  • Canvas Dimension?A4 (210 x 297mm) or 12 x 9inch (228.6 x 304.8mm)
  • Frame Material?Paperboard, corrugated paperboard
  • Battery Life?30 days with AA batteries?In standby mode, all modules will shut down automatically except zone W.?
  • LED Module Interface?4 Channel 40Ma I/O Interface?Zone Z??4 Channel 500mA Output Interface(Zone X)
  • Extension Interface?4 Channel 3PIN for Sensor/Actuator?Zone S?/1 Channel UART/1 Channel I2C
  • Wakeup Interface?1 Channel 3PIN for Sensor (Zone W?
Pallete Controller
  • MCU?ATmega32u4
  • Working Voltage?3 ~ 5V
  • Digital IO?16(40ma)
  • PWM?4
  • Analog Input?3
  • UART: 1
  • I2C: 1
  • USB: 1
  • Power Interface: 2
  • Flash Memory: 32 KB (ATmega32u4, 4K for bootloader)
  • SRAM Memory: 2.5 KB (ATmega32u4)
  • EEPROM Memory: 1 KB (ATmega32u4)
  • Clock Speed: 8MHz
  • Controller Size: 65.5 x 44 x 11.8mm(2.58x1.73x0.46")
DOCUMENTS
