Google Coral Development Board
код: USA274
  • Google Coral Development Board
The Coral Dev Board is a single-board computer with a removable system-on-module (SOM) that contains eMMC, SOC, wireless radios, and the Edge TPU. You can use the Dev Board as a single-board computer when you need accelerated ML processing in a small form factor, but it also serves as an evaluation kit for the SOM. You can use the dev board to prototype internet-of-things (IOT) devices and other embedded systems that demand fast on-device ML inferencing, and then scale to production using just the 40 mm × 48 mm SOM board combined with your custom PCB hardware using board-to-board connectors.
The SOM is based on NXP's iMX8M system-on-chip (SOC), but its unique power comes from the Edge TPU coprocessor. The Edge TPU is a small ASIC designed by Google that provides high performance ML inferencing with a low power cost. For example, it can execute state-of-the-art mobile vision models such as MobileNet v2 at 100+ fps, in a power efficient manner.
The baseboard includes all the peripheral connections you need to prototype a project, including USB 2.0/3.0 ports, DSI display interface, CSI-2 camera interface, Ethernet port, speaker terminals, and a 40-pin GPIO header.
Features:
  • Edge TPU Module (SOM)
    • NXP i.MX 8M SOC (Quad-core Cortex-A53, plus Cortex-M4F)
    • Google Edge TPU ML accelerator coprocessor
    • Cryptographic coprocessor
    • Wi-Fi 2x2 MIMO (802.11b/g/n/ac 2.4/5GHz)
    • Bluetooth 4.1
    • 8GB eMMC
    • 1GB LPDDR4
  • USB connections
    • USB Type-C power port (5V DC)
    • USB 3.0 Type-C OTG port
    • USB 3.0 Type-A host port
    • USB 2.0 Micro-B serial console port
  • Audio connections
    • 3.5mm audio jack (CTIA compliant)
    • Digital PDM microphone (x2)
    • 2.54mm 4-pin terminal for stereo speakers
  • Video connections
    • HDMI 2.0a (full size)
    • 39-pin FFC connector for MIPI DSI display (4-lane)
    • 24-pin FFC connector for MIPI CSI-2 camera (4-lane)
  • MicroSD card slot
  • Gigabit Ethernet port
  • 40-pin GPIO expansion header
  • Supports Mendel Linux (derivative of Debian)
Documents:
